neazoi
Advanced Member level 6
Hello, I have build this oscillator circuit, followed by two buffers (only one shown) and I would like to apply automatic level control to the circuit, so that the output level is constant if different crystals are switched.
I have tested two ideas. The first is using a BJT as a variable resistor, to form a voltage divider, to limit the voltage to the oscillator, which limits the output power.
The second is, using an LDR to alter the resistor value at the gate of the fet.
A third way, which I have not tested yet (although it should work) is to limit the output power of the oscillator, by including a voltage divider at the output of the oscillator, set with an LDR as previously.
The first two ways I have tested worked up to a point but the output power still had some variations and the circuits behaved more like limiters rather than ALC. The output power was more constant but much less attenuated at all bands.
Can a better ALC circuit be applied to my circuit, that will allow for almost full and constant output level at all bands?
