coolchip
Full Member level 2
automatic irrigation system
Hi all,
I am planning to build a small automatic irrigation system for my garden.
The electrodes in the soil will detect when water is required.This will switch on the water flow until moisture is restored in the soil.
I am looking for cheapest way to control water flow ( on or off).
Is it possible using float or I will have to use a pump?The water will be drawn from a overhead tank or even from tap whatever is easier.
If someone knows of such project then kindly post suggestion/links.
Hi all,
