Automatic insertion of metal fill to meet the metal density for 28nm technology!
Chtn
I am actually writing a calibre rule deck for 28nm, which shuld check for metal density violations and fill dummy metal to overcome violations automatically.! so I some need assistance with this.
When i check DENSITY command on test case with only metal1 inside pr boundary, i am not able to figure out how is it computing densities and reporting ceratin polygons.
Need some assistance plz!
You might want to take a look at the Density chapter in the "Calibre Solutions for Physical Verification" manual. This ships standard with the documentation. (Look for "calbr_solns_pv_user.pdf") If the explanations there are not detailed enough, it has links to the various commands which should have more detail. Failing that, customer support may be able to answer specific questions.
