archiees
Member level 1
I found this attached schematic as part of an oscillator circuit. It is supposed to be an AGC stage in which V3 is a portion of the ac output of the oscillator (through inductive coupling) which is being fed to the AGC. The output of the opamp controls some bias voltage which controls the amplitude of the oscillations. What i dont understand is, how by varrying the dc value of V2 voltage source we can control the output of the opamp and hence the bias of the transistor in oscillator.
So, the voltage after the R6 is fed to the transistor bias in the main oscillator circuit.
Explaination of the circuit will help me a lot. thanks
