Automatic gain control loop
Ghost Tweaker
Member level 5
Member level 5
I'm working on the design of a "discrete" AGC loop for a GPS receiver (>60dB gain required...). Does someone have a good tutorial for this kind of design?
thanx
Ghost
a common architecture uses a 2 bit (sign/magnitude) quantizer. The AGC gain is set to obtain a 30% duty cycle of the averaged mag output.
Remember, the GPS signal is below the thermal noise. The AGC loop thus regulates on noise generated in the frontend.
Best,
bmalp98
