Jeffo
Newbie
Are fan speeds to cool the CPU an automatic system? i.e higher temp = higher rpm? If so how does this work? I know there is a temperature sensor on the CPU, the output for this is a voltage, does this mean the output is filtered and amplified and then fed to the fan through the motherboard? more volts higher speed?
Just need to understand how this feedback system works
