aq_mishu
Full Member level 4
Guys, Please help me to design this... (Which may lead to finally design a Instant Power Supply (IPS) as backup power source for household with built in charger, inverter etc.)
I first want to convert all my existing PSUs (Linear) to SMPS based. So voltage regulation will be by switching mode... with high current/controllable current... But as general bridge rectifier of diodes involve large voltage drop and high wattage consumtion, means low efficiency, i want to keep it within 80% or above. Thus my plan is to use MOSFet instead of diode. after a lot og googleing, i found it... now can you tell me the values?? Say I need 30VAC with 10A (Max... if more, i'll work on it later) and regulated output would be 24VDC. As like linear ones, can i use the same filter part to filter ripples? first attempt of mine is to replace the bridge with mosfet and then to change the regulator with a pwm. step by step... so finally it will be a complete big project...
now guys, i need holp on designing this bridge... here is the file i got...
Mishu~~
Mishu~~
