Auto on switch after power failure
badboydas
Newbie level 5
Newbie level 5
Hi All
Hope one of you clever people can help. I have a HDMI switch in the loft connected to a UPS, every time there is a long power cut and the UPS cuts out the unit does not switch back on, unless I go up in the loft and push the momentary switch(what a pain). Opening the unit shows a tactile switch, putting a meter across the switch shows 0volts when the switch is pressed and released there is a constant 2.31volts. I`m pretty sure this could be completed with a transistor and a couple of resistors but my electronics sucks.:)
cheers
It probably will not work if you install a short across the switch (which would only need a resistor to do). If that could do it, then there is no need for the switch in the first place.
I think the unit turns on only after you let up the switch after pressing it down.
A solution would be to install a relay across the switch.
The relay is activated by a circuit which comes on for a fraction of a second after mains power returns.
The diode and capacitor pass current for a short time, until the capacitor is charged up.
The 100k resistor discharges the capacitor during a blackout, so the circuit is ready to operate when power resumes.
I like the circuit Brad!, i would actually use a transistor to drive the relay and capacitively the base to the units +Vcc line, same thing but no extra transformer. Easiest way, is to wire the relay in the loft to the switch and power it downstairs from a "wall wart" PSU.
Frank
Thanks guys
the tranny for the HDMI switch is external, input is 12v 5A so I can tap of that. Bradtherad I think you got It, correct me if I`m wrong remove the diode from your circuit solder directly from the input? Chuckey can you eleborate with a sketch given that I can tap into the regulated switch mode supply (off the pcb). Forgive me for checking out both of your inputs, but I need simply but effective.
cheers
Darren
Thanks guys
cheers
Darren
Nice one Bradtherad, :)
cheers
Darren
Nice one Bradtherad, Would that be a PNP or a NPN general purpose transistor. forgive my ignorance:)
cheers
Darren
NPN. The arrow points in the direction of the PN junction. It points in the direction of current flow.
If you only have a PNP, then the schematic is easy to revise by mirroring it.
Component values may need adjusting, to get everything to work right.
Thanks Radthebrad
To be honest I just come back from the pub (grey cells went missing) As soon as I clicked post I knew how dumb I was:)
I`ll put it to the test later and let you know how it went.
cheers
Spot on Bradtherad and Chuckey
All up and running, nice job lads
Many thanks
Darren
