nologic
Newbie level 1
Once in a while I left the car dome light on and the battery becomes drained or semi-drained the next day.
I want to add an auto-off circuit to the dome light so the dome light would turn off after about 5 minutes. When the light is off, the timing circuit should draw less than 5mA.
The timing should be adjustable and does not need to be precise.
There is no button or switch in this circuit. It is simply reset when the power is turned off (e.g. car door closed or light switched to OFF). So if the dome light is on for 5 minutes and the timer kicks in and turn off the light, I can switch the light off and on (using the car's dome light switch) and get another 5 minutes of light.
The light itself would draw anywhere from 50mA to 1A, depending on what light bulb/LED I replace it with. Car voltage is standard 12V.
I'd like to know if there's existing product to do this? Someone already posted a circuit to do this somewhere? Or, someone could point me to an IC that can help me do this?
