Hello,
I am in the process of creating a set of standard cells to be used in larger designs. I currently have the spice netlist models of these cells, and have performed library characterization to generate the .lib and .db library files.
Now, I would like to generate the layout of these cells, hopefully without having to manually lay out every cell.
I have come across tutorials for autolayout, but these tend to assume that the standard cell library layout is already available to the user, and it simply uses multiple instances of these standard cells to generate the desired layout.
Is there a way to autolayout the standard cells?
Thanks.
