What was your problem with the Vbe multiplier? I don't understand how other audio amplifiers can work with a Vbe multiplier if those supply voltage varies.
Let's see this:
http://en.wikipedia.org/wiki/File:OpAmpTransistorLevel_Colored_Labeled.svg
Also a push-pull output stage, supply can vary from 7V to 36V, and use a Vbe multiplier. Not an audio power amplifier, but with bigger output transistors it could be.
And not MOSFET, but I think it doesn't matter too much. What is vertical MOSFET in your term?
