Audio Technica AT92E - mounting problem
andreidaniel
Member level 2
Member level 2
Romania, Iasi City
Hi! I bought an AT 92E cartridge with universal mount P / 1.2" adaptor. Works fine, eliptical stylus, higher frequencies.. The only doubt is that is a little bit higher than the oldest AT95 (this one had a problem with the needle). In fact the arm seems to be (overall) raised (when I put on the record) and not a little bit bent like the previous case with the old cartridge.. Is this a problem? I re-adjusted to 0 the tracking force and the set it at 1,25 and also the antiskate to 1,25.
Are there some headshells which delivers P mount? All the tonearms which I have saw had the P connectors integrated..
