Audio programming, but sound not out . Please help me.
ezyneab
thailand
My program
#include <math.h>
#include <stdio.h>
#include <stdlib.h>
#include "dsk6713_aic23.h" //codec-DSK support file
Uint32 fs=DSK6713_AIC23_FREQ_8KHZ; //set sampling rate
#define BIT_PER_SAMPLE 16
int input_dec;
int m=5, n=31, k=16, t=3, d=7;
int length=31;
int p[6]; // irreducible polynomial
int alpha_to[32], index_of[32], g[16];
int recd[31], data[16], bb[16];
int numerr, errpos[32], decerror=0;
typedef struct list
short data;
struct list *previous,*next;
}node;
node *first=NULL;
node *back=NULL;
//===========Decimal to Binary==================
void de2bi(char bin[BIT_PER_SAMPLE],int dec)
int j, temp1, temp2=dec;
for(j=0; j<BIT_PER_SAMPLE; j++)
temp1=(int)floor((float)temp2/2);
bin[j]=temp2-temp1*2;
temp2=temp1;
return;
//Primitive polynomial of degree 5
void read_p()
register int i;
p[0]=p[2]=p[5]=1; // x^5 + x^2 + 1
p[1]=p[3]=p[4]=0;
// generate GF(2**m) from the irreducible polynomial p(X) in p[0]..p[m]
// lookup tables: index->polynomial form alpha_to[] contains j=alpha**i;
// polynomial form -> index form index_of[j=alpha**i] = i alpha=2 is the
// primitive element of GF(2**m)
void generate_gf()
register int i, mask;
mask=1;
alpha_to[m]=0;
for(i=0; i<m; i++)
alpha_to=mask;
index_of[alpha_to]=i;
if(p!=0)
alpha_to[m]^=mask;
mask<<=1;
index_of[alpha_to[m]]=m;
mask>>=1;
for(i=m+1; i<n; i++)
if(alpha_to[i-1]>=mask)
alpha_to=alpha_to[m]^((alpha_to[i-1]^mask)<<1);
else
alpha_to=alpha_to[i - 1]<<1;
index_of[0]=-1;
// Compute generator polynomial of BCH code of length = 31, redundancy = 15
void gen_poly()
register int ii, jj, ll, kaux;
int test, aux, nocycles, root, noterms, rdncy;
int cycle[16][6], size[16], min[16], zeros[16];
// Generate cycle sets modulo 31
cycle[0][0]=0; size[0]=1;
cycle[1][0]=1; size[1]=1;
jj=1; // cycle set index
do
// Generate the jj-th cycle set
ii=0;
do
ii++;
cycle[jj][ii]=(cycle[jj][ii-1]*2)%n;
size[jj]++;
aux=(cycle[jj][ii]*2)%n;
while(aux!=cycle[jj][0]);
// Next cycle set representative
ll=0;
do
ll++;
test=0;
for(ii=1; ((ii<=jj)&&(!test)); ii++)
// Examine previous cycle sets
for(kaux=0; ((kaux<size[ii])&&(!test)); kaux++)
if(ll==cycle[ii][kaux])
test=1;
while((test)&&(ll<(n - 1)));
if(!(test))
jj++; // next cycle set index
cycle[jj][0]=ll;
size[jj]=1;
while(ll<(n-1));
nocycles=jj; // number of cycle sets modulo n
// Search for roots 1, 2, ..., d-1 in cycle sets
kaux=0;
rdncy=0;
for(ii=1; ii<=nocycles; ii++)
min[kaux]=0;
for(jj=0; jj<size[ii]; jj++)
for(root=1; root<d; root++)
if(root==cycle[ii][jj])
min[kaux]=ii;
if(min[kaux])
rdncy+=size[min[kaux]];
kaux++;
noterms=kaux;
kaux=1;
for(ii=0; ii<noterms; ii++)
for(jj=0; jj<size[min[ii]]; jj++)
zeros[kaux]=cycle[min[ii]][jj];
kaux++;
g[0]=alpha_to[zeros[1]];
g[1]=1; // g(x) = (X + zeros[1]) initially
for(ii=2; ii<=rdncy; ii++)
g[ii]=1;
for(jj=ii-1; jj>0; jj--)
if(g[jj]!=0)
g[jj]=g[jj-1]^alpha_to[(index_of[g[jj]]+zeros[ii])%n];
else
g[jj]=g[jj-1];
g[0]=alpha_to[(index_of[g[0]]+zeros[ii])%n];
//===============Encode_bch==============================
// Calculate redundant bits bb[], codeword is c(X) = data(X)*X**(n-k)+ bb(X)
void encode_bch(int data[16], int bb[16])
register int i, j;
register int feedback;
for(i=0; i<length-k; i++)
bb=0;
for(i=k-1; i>=0; i--)
feedback=data^bb[length-k-1];
if(feedback!=0)
for(j=length-k-1; j>0; j--)
if(g[j]!=0)
bb[j]=bb[j-1]^feedback;
else
bb[j]=bb[j-1];
bb[0]=g[0]&&feedback;
else
bb[j]=bb[j-1];
bb[0]=0;
//==============decode_bch================
void decode_bch()
register int i, j, q;
int elp[3], s[5], s3;
int count=0, syn_error=0;
int loc[3], reg[3];
int aux;
// first form the syndromes
for(i=1; i<=4; i++)
s=0;
for(j=0; j<length; j++)
if(recd[j]!=0)
s^=alpha_to[(i*j)%n];
if(s!=0)
syn_error=1; // set flag if non-zero syndrome NOTE: If only error detection is needed, then exit the program here...
s=index_of[s]; // convert syndrome from polynomial form to index form
if(syn_error) // If there are errors, try to correct them
if(s[1]!=-1)
s3=(s[1]*3)%n;
if(s[3]==s3) // Was it a single error ?
recd[s[1]]^=1; // Yes: Correct it
else // Assume two errors occurred and solve for the coefficients of sigma(x), the error locator polynomail
if(s[3]!=-1)
aux=alpha_to[s3]^alpha_to[s[3]];
else
aux=alpha_to[s3];
elp[0]=0;
elp[1]=(s[2]-index_of[aux]+n)%n;
elp[2]=(s[1]-index_of[aux]+n)%n;
for(i=1; i<=2; i++) // find roots of the error location polynomial
reg=elp;
count=0;
for(i=1; i<=n; i++) // Chien search
q=1;
for(j=1; j<=2; j++)
if(reg[j]!=-1)
reg[j]=(reg[j]+j)%n;
q^=alpha_to[reg[j]];
if(!q) // store error location number indices
loc[count]=i%n;
count++;
if(count==2) // no. roots = degree of elp hence 2 errors
for(i=0; i<2; i++)
recd[loc]^=1;
//=========== binary 16 bits to decimal==============
int bi2de(char bin[BIT_PER_SAMPLE])
int op=0;
long int power_vector[BIT_PER_SAMPLE];
int j;
int i, c=0;
int flag=0;
power_vector[0]=1;
//====================1's complement==================
if(bin[15]==1)
{ flag=1;
for (i=15; i>=0; i--)
if(bin==0)
bin=1;
else
bin=0;
// printf("%d",bin);
//=================2's complement=======================
for(i=0; i<16; i++)
if(i==0)
if(bin==0)
bin=1;
else
bin=0;
c=1;
else
if(c==1 && bin==0)
bin=1;
c=0;
else if (c==1 && bin==1)
bin=0;
c=1;
for(j=1; j<BIT_PER_SAMPLE; j++)
power_vector[j]=power_vector[j-1]*2;
//================= convert bit to decimal digit===============
op+=power_vector[j]*bin[j];
if(flag==1)
op=(-2*op)+op;
flag=0;
return(op);
//======================main_code==========================
void main()
char temp_binary[BIT_PER_SAMPLE],temp_decimal[BIT_PER_SAMPLE];
int *binary_buffer;
int *out_buffer;
int j,i=0;
int count=0,count_bit;
char temp[BIT_PER_SAMPLE];
int c=0;
int z=0;
read_p(); // read generator polynomial g(x)
generate_gf(); // generate the Galois Field GF(2**m)
gen_poly(); // Compute the generator polynomial of BCH code
comm_poll(); //init DSK, codec, McBSP
DSK6713_LED_init(); //init LED from BSL
DSK6713_DIP_init(); //init DIP from BSL
short voice ;
node *currptr;
while(DSK6713_DIP_get(3) == 0)
{ c++;
count++; //count data
DSK6713_LED_on(3); //turn on LED#3
voice=input_sample();//store input data into buffer
printf("%d\n",voice);
// scanf("%d",&voice);
if(back==NULL)
currptr=(node*)malloc(sizeof(node));
back=currptr;
first=currptr;
currptr->data=voice;
currptr->previous=NULL;
currptr->next=NULL;
else
back->next=currptr;
currptr->previous=back;
back=currptr;
back->next=NULL;
DSK6713_LED_off(3);
count_bit=count*BIT_PER_SAMPLE;//count bit
// printf("Bit all=%d\n",count_bit);
binary_buffer = (int *) malloc(count_bit*sizeof(int)); //binary_buffer dynamic array
while(first!=NULL) //while first data
input_dec=first->data;
de2bi(temp_binary, input_dec); //Goto func de2bi
//=================define_binary_16bit=====================
for(j=15; j>=0; j--) //for 16 bit
binary_buffer=temp_binary[j]; //tranfer temp_binary to dynamic array
// printf("%d",binary_buffer);
i++;
first=first->next;
/* for(i=0;i<=(count_bit-1);i++)
//====================dividing_binary_data================
for(j=0; j<count; j++)
for(i=0; i<16; i++)
data=binary_buffer[16*j+i];
// printf("%d",data);
// BCH encoding
encode_bch(data, bb); // encode data
recd=bb; // first (length-k) bits are redundancy
// printf("%d",recd);
for(i=0; i<k; i++)
recd[i+length-k]=data; // last k bits are data
// printf("%d",recd[i+length-k]);
for (i = 0; i < length; i++)
printf("%d", recd); //print codeword
printf("codeword\n");
//Input Error
// BCH decoding
decode_bch(); //decoded data
for(i=length-k; i<length; i++) // decoding errors: compare only the data portion
{ if(data[i-length+k]!=recd)
decerror++;
for(i=0; i<16; i++)
binary_buffer[16*j+i]=recd[i+length-k];
printf("%d",binary_buffer[16*j+i]);
printf("decode\n");
out_buffer = (int *) malloc(count*sizeof(int));
// Convert 16-bit binary 'binary_buffer' to decimal 'out_buffer'
for(i=0; i<count; i++)
temp_decimal[j]=binary_buffer[16*i+j];
// printf("%d",temp_decimal[j]);
z=0;
temp[z]=temp_decimal[j];
// printf("%d",temp[z]);
z++;
out_buffer=bi2de(temp);
// output_sample(out_buffer*10);
printf("%d\n",out_buffer);
free(binary_buffer) ;
Help me to do.
Program to voice out.
