Tyler Grey
Junior Member level 1
I bought a ATX computer power supply last year to make a power supply for hobby electronics. And while using it, I got curious of how much -12V rail would push. It said 0.3A, but I tested it with a multimeter anyways, and got around 6~8A. It wasn't stable and after 2~3 seconds, it made some popping sound and shut down.
The symptoms are : When you give power to the power supply and plug the power cable, you get power for the 5V Standby rail(which should be on all the time when the PSU gets power).
When you turn on the PSU, you get voltages for all the rails(+12V, -12V, +5V, +3.3V) for less than a second and everything goes down to 0V except for the 5V stand by, 5V power good(it powers on when PSU is switched on), and 5V
Now, I just took it apart and took a closer look inside it. None of the components seem burnt or anything horrible. They all seem good on my eyes. There is a NTC 5D-9 power thermistor which looks good on my eyes, but is currently the most suspicious component for now.(I get 0 ohms with my multimeter, but that reading is when it's connected to the PCB)
What do you think is the problem?? I haven't given the PSU and power since last year so the capacitors are fully discharged and I checked it again by shorting them with a screwdriver. It's not a expensive or premium power supply. I bought it for 15 bucks and while I can just make a new one, I'd really like to repair the one I have now. Any ideas??
