ATmel SAMA5D34 Industrial board,CAN, RS485, RS232 support,1GMBit Ethernet on board
armdevs
Newbie level 3
Newbie level 3
<a href=" http://armdevs.com/IPC-SAMA5D34.html">http://armdevs.com/IPC-SAMA5D34.html</a>
IPC-SAMA5D34 Features
Working Temperature: -40 to +85 Celsius
Atmel SAMA5D34 Cortex-A5 CPU, 536 MHz
512 MB DDR2 SDRAM, 256 MB NAND Flash
Integrated 1GMBit Ethernet on board
TFT LCD with touchscreen, Audio
CM-SAMA5D34 CPU Board Feature
CPU processor
ATMEL SAMA5D34 ARM processor
Cortex-A5, working at 536MHZ.
DDR2 RAM Memory
512MB DDR2 RAM, 32bit data bus
Flash Memory
256MB Nand Flash
4MB SPI Flash
Pin interface
2 x 60 pin 2.0mm space DIP connector
1 x 30 pin 2.0mm space DIP connector
Resource: USB, Ethernet, Serial, SSC Audio, CAN, SDIO,LCD, Touch, SPI, IIC, GPIO
On-board resources
2 x LED
Supply Voltage 3.3V
PCB Size
8 layer, 52 x 64 (mm)
Low power consumption, only 0.5W
IPC-SAMA5D34 Base Board Feature
Display
LCD: 40Pin connector, 2.54mm , 16 TFT LCD support
Support 4.3”LCD, 7”LCD, 10.4”LCD
Ethernet
1 Gbit Ethernet support, Rj45 interface
Serial Port
Total five Serial port:
> Debug Serial: RS232 Level, DB9 connector
> USART0: RS485 level, connector
> USART1: TTL Level(5-wire, expand with 2x5Pin header COM0 )
> USART2: RS232 Level(Expand with 3.81 connector)
> USART3: TTL Level(5-wire, expand with 2x5Pin header COM0 )
CAN Bus
1 x CAN Bus 2.0
Standard interface
Two USB Host
One USB Device interface
One Audio In/Out interface
One TF card interface
Board Resource
Key: 3 user key, contain one Reset Key and two User key
One RTC Battle
GPIO
16 GPIO interface
PCB Size
145 x 110mm, 2 layer
Power In
12V
System
Linux 3.6.9
Email: market@armdevs.com
More details,please feel free to contact COREWIND
