"A control bit (RCEN) in the Flash Memory selects the On-chip RC Oscillator as
the clock source when programmed (“0”). The AT90S1200 is normally shipped with this
bit unprogrammed (“1”). Parts with this bit programmed can be ordered as
AT90S1200A. The RCEN-bit can be changed by parallel programming only."
