[AVR] ATmega8 Zerocross Detection circuit
tahertinu
Member level 4
Member level 4
Ahmedabad
Hi all,
I am working on AC dimmer circuit , for that i have have interfaced the Zero Cross Detection circuit with ATmega16 INT0 pin. INT0 is configured as a rising edge. here i am attaching image which shows the working of Zero cross detection is good. but when i interface its output with ATmega INT0 pin, the Zero Cross Pulsed gets down and nothing happen on INT0 pin. i have tested INT0 code separately which also working as expected. I am not getting where i am doing anything wrong? please somebody help me who has worked with such project ever before
Here is a code snip which gives INT0 routine and Int0 Configuration as rising edge.
 *  Written in AVR Studio 5 / AVR Studio 6
 *  Compiler: AVR GNU C Compiler (GCC)
 *  Author: AVR Tutorials
 *  Website: www.AVR-Tutorials.com
#include <avr/io.h>
#include <avr/interrupt.h>
#define F_CPU 16000000UL
#include <util/delay.h>
#define DataPort	PORTC	// Using PortC as our Dataport
#define DataDDR		DDRC
//Interrupt Service Routine for INT0
ISR(INT0_vect)
	unsigned char i, temp;
	cli();
	//_delay_ms(500); // Software debouncing control
	//temp = DataPort;	// Save current value on DataPort
	/* This for loop blink LEDs on Dataport 5 times*/
	DataPort = 0x00;
	for(i = 0; i<100; i++)
		_delay_us(200);	// Wait 5 seconds
		//_delay_us(200);	// Wait 5 seconds
 	DataPort = 0xFF;
	//DataPort = temp;	//Restore old value to DataPort
	sei();
int main(void)
	DDRD = 1<<PD2;		// Set PD2 as input (Using for interupt INT0)
	PORTD = 1<<PD2;		// Enable PD2 pull-up resistor
	DataDDR = 0xFF;		// Configure Dataport as output
	DataPort = 0xFF;	// Initialise Dataport to 1
	GICR = 1<<INT0;					// Enable INT0
	MCUCR = 1<<ISC01 | 1<<ISC00;	// Trigger INT0 on rising edge
	sei();				//Enable Global Interrupt
    while(1)
	/*	if(DataPort >= 0x80)
			DataPort = 1;
		else
			DataPort = DataPort << 1;	// Shift to the left
		_delay_ms(500);	// Wait 5 seconds */
		if(!(PIN_1 & (1<<SW_1))) //If switch is pressed
			toggle(LED_PORT,LED_1);
			_delay_ms(1000);
		else if(!(PIN_1 & (1<<SW_2))) //If switch is pressed
		toggle(LED_PORT,LED_2);
		_delay_ms(1000);
When i use this Zero Cross Detection pulses as a normal switch its working good, but when i use it with INT0 pin the pulse get destroyed and nothing happens as attached images
You are using external interrupt to detect an event that happens every 20ms, and you keep a delay of 20ms inside interrupt? First remove all delays from interrupt and then try again. If you want to do tricks with the LED, try something different, maybe from main().
I have removed all unnecessary delays as it was debug code. and i have used
DDRD= 0x00 instead of setting PD0 to high i have kept it on low for input.
code is working in simulation. need to check in real hardware. I am grateful towards your precious response
as i am able to work the circuit in Proteus simulation it seems it is correct, but in Proteus i am getting warning. not running in real time due to CPU overload, so what dose it means ? is it something wrong with programming or schematic diagram? here i am attachingProteus SimulationLOG.pngRunnin_ZeroCross.jpg two images of working simulation ans stopped one. pleas guide me somebody to the right way if i am ding some thing wrong with the schematic or program.
Thanks in Advance.
As far as I remember the message means exactly what it's saying. The simulation works correctly, however the Proteus stopwatch is not synchronized with your windows clock while you are running the simulation (run at different speed), due to high processing load. So, it should not affect results you're getting from the simulation, however it is the best practice to double-check the timing through your own calculation and real-world testing of the system.
Thanks a lot for your valuable eply Funkehed. :)
Hi all.
As I have developed that ZeroCross Detector Circuit and Tested it on CRO but i am getting this kind of wave forms instead of pulse at zero crossing. please let me know what can be the issue in my circuit? IMG-20140725-WA0015.jpg
