ATmega328p and USB conection to PC
zarzisur
Newbie level 5
Newbie level 5
I wanted to blink a led every 1s connected with PORTB0 pin of Atmega 328p microprocessor. I have used USBASP programmer.The connection USBASP with 328p is like this: MOSI-17 MISO-18 SCK-19 RESET-1 GND-8 VCC-7 I have used a LM7805 to power the microprocessor from 9V battery,i have used two 1uF capacitor in input and output port of LM7805. I wanted to implement this code:
Which should toggle LED at portb0 in every 1s.
But my led starts to glow for around 5s after the microprocessor has burnt and keeps glowing from then,it doesnt stop anytime after then.
the output window of atmelstudio 7 shows this:
avrdude.exe: warning: cannot set sck period. please check for usbasp firmware update. avrdude.exe: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude.exe: Device signature = 0x1e950f avrdude.exe: NOTE: FLASH memory has been specified, an erase cycle will be performed To disable this feature, specify the -D option. avrdude.exe: erasing chip avrdude.exe: warning: cannot set sck period. please check for usbasp firmware update. avrdude.exe: reading input file "C:\Users\Rony\Documents\Atmel Studio\7.0\1st avr prog\1st avr prog\Debug\1st avr prog.hex" avrdude.exe: writing flash (196 bytes):
Writing | ################################################## | 100% 0.14s
avrdude.exe: 196 bytes of flash written avrdude.exe: verifying flash memory against C:\Users\Rony\Documents\Atmel Studio\7.0\1st avr prog\1st avr prog\Debug\1st avr prog.hex: avrdude.exe: load data flash data from input file C:\Users\Rony\Documents\Atmel Studio\7.0\1st avr prog\1st avr prog\Debug\1st avr prog.hex: avrdude.exe: input file C:\Users\Rony\Documents\Atmel Studio\7.0\1st avr prog\1st avr prog\Debug\1st avr prog.hex contains 196 bytes avrdude.exe: reading on-chip flash data:
Reading | ################################################## | 100% 0.10s
avrdude.exe: verifying ... avrdude.exe: 196 bytes of flash verified
avrdude.exe: safemode: Fuses OK
avrdude.exe done. Thank you.
WHAT IS THE PROBLEM?
i have used also used a external 16mhz clock,but still it shows ssame result.
One of my friend told me that in windows 10 i have to turn offf the device signate.I have turned off device signature and when i tried to update the driver again it shows that my driver is already up to date so it wont take a new driver.
Should be clock issues
Set proper clock rate. Have a look into fuse bytes in datasheets
Do some simple test like just turning on a bit rather than toggling
Maybe it's the RESET connection.
Show us your complete curcuit.
BTW: Please set up all ports. Don't let any pin floating, in doubt use the "pull up" feature.
Klaus
