sunsina
Member level 2
atmega programmer schematic
Do you Have any Schematic for Programming AVR ATMEGA128.
I had Post One topic for this programmer before but i tried more than 5 schematics!
And none Of them Worked for ATMEGA128 and I don't Know Why .
If you Had Programmed ATMEGA128 Please Help Me :
a - How to Program ATMEGA128-H
b - The Programmer Hardware Schematics
c - The Pin Connections between ATMEGA128 IC and Programmer.
(I Prefer PIN Numbers to their Identification Eg. In ATMEGA128 PDF from Atmel
There are some conflicts Between MOSI and MISO Pins)
d - Which Pins Of ATMEGA128 Must be Connect to VCC ,or XTAL (if it is Needed),...
e - Power Supply and the Current that Programmer use.
Tanx in Advance
Tanx in Advance
