Justin Wenger
Newbie level 5
I want to make several codes work together.(ex. seven segment code+ LED code+ timer code + ....)
Each code works properly on its own, but when I try to combine it, problem happens.
Only one code works even though I combined these codes together.
Code below is a code using seven segment + timer + UART at the same time,
and I want it to count it down from 30:00 to 00:00 while I can use UART at the same time.
But only the timer code works and UART code doesn't.
If you know what the problem is, please give me an advice.
#define F_CPU 1600000
#include <avr/io.h>
#include <avr/interrupt.h>
#include <util/delay.h>
#include <stdio.h>
const unsigned char Segment_Data[] =
{0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x27,0x7F,0x6F};
char COLUMN[4]={0,0,0,0};
int Cnt=0;
int SHOW_NUMBER=0, SHOW_NUMBER12=30, SHOW_NUMBER34=0;
void Show4Digit(int number);
void ShowDigit(int i, int digit);
void uart0_init(void);
int Putchar(char message);
void uart(void);
char getchar1(void);
ISR(TIMER0_OVF_vect) { // TIMER0 has overflowed
Cnt++;
if(Cnt==244){
SHOW_NUMBER34--;
Cnt=0;
if(SHOW_NUMBER34<0){
SHOW_NUMBER12--;
SHOW_NUMBER34=59;
if(SHOW_NUMBER12<0){
SHOW_NUMBER12=0;
SHOW_NUMBER34=0;
int main(void) {
uart0_init();
char c;
fdevopen(Putchar, 0);
printf("\n\rUART_Test");
DDRC = 0xff; DDRA = 0xff; PORTC = 0x00;
TCCR0 = 0x06; // Normal mode, prescale 256, 16M/256=62500Hz
TCNT0 = 0x00; // n=0, 256 count, 62500Hz/256=244.14Hz
TIMSK = 0x01; // timer0 OVERFLOW interrupt enable
SREG |= 0x80; // Global Interrupt Enable
while (1) {
SHOW_NUMBER=SHOW_NUMBER12*100+SHOW_NUMBER34;
Show4Digit(SHOW_NUMBER);
void uart(void){
uart0_init();
char c;
while(1){
c = getchar1();
printf("%c", c);
void Show4Digit(int number) {
COLUMN[0] = number/1000; COLUMN[1] = (number%1000)/100;
COLUMN[2] = (number%100)/10; COLUMN[3] = (number%10);
for(int i=0;i<4;i++) {
ShowDigit(COLUMN[i],i);
_delay_ms(2); // wait for a second
void ShowDigit(int i, int digit) {
PORTC=~(0x01<<digit);
PORTA = Segment_Data[i];
void uart0_init(void) {
UCSR0B = 0x00; //disable while setting baud rate
UCSR0A = 0x00;
UCSR0C = 0x06;
UBRR0L = 0x67; //set baud rate lo
UBRR0H = 0x00; //set baud rate hi
UCSR0B = 0x18;
int Putchar(char message) {// Putchar "P" cVde
while (((UCSR0A>>UDRE0)&0x01) == 0) ; // UDRE, data register empty
UDR0 = message;
return 0;
char getchar1(void) {
while(!(UCSR0A&0x80));
return UDR0;
