dharanikumarsrvn
Junior Member level 1
what is called read/modify/write in atmega 16 operation ?
PORTB=0x01; // this is a write operation
PORTB= PORTB | 0x01; // this is a RMW operation , it reads PORTB value, ORes it with 1 and then writes the result back
Actually this is not an RMW operation, at least it shouldn't regardless of compiler. This is an atomic operation, uninterruptible by other ISRs.Code:PORTB= PORTB | 0x01; // this is a RMW operation , it reads PORTB value, ORes it with 1 and then writes the result back
Do not use Read-Modify-Write instructions (SBI and CBI) to set or clear the MPCM bit.
The MPCM bit shares the same I/O location as the TXC Flag and this might accidentally
be cleared when using SBI or CBI instructions.
But on most AVR's (the devices which are exceptions to this rule have notes in the Register Summary section of the datasheet), even these so-called bitwise operations actually operate on the whole register, even if only one bit is being changed.
In a single instruction cycle (two clocks in this case), the whole I/O register is read into a scratch space, a single bit is modified, and the whole scratch register is written out to the I/O register again.
Actually that forum is a valuable source of info when it comes to AVR, any wrong answer in that forum would be confronted very fast from other members especially when it comes to things like that which are black or white.A post from another forum is not exactly what we were looking for to clear this issue
The compiler just shows the SBI instruction used, the claim that this is not a RMW instruction is made by you so the compiler has nothing to do as proof of what you say.Compiler's disassembler speaks for itself.
I will refer to page 123 of the instruction set pdf, where it is written that for tiny (which is an AVR as well), the sbi command is executed in 1 cycle. Is it possible for an RMW command to be executed in 1 cycle?
Words : 1 (2 bytes)
Cycles : 2
Cycles XMEGA: 1
Cycles Reduced Core tinyAVR:1
Some of the Status Flags are cleared by writing a logical one to them. Note that the CBI and SBI
instructions will operate on all bits in the I/O Register, writing a one back into any flag read as
set, thus clearing the flag. The CBI and SBI instructions work with registers $00 to $1F only.
Some of the Status Flags are cleared by writing a logical one to them. Note that, unlike most
other AVRs, the CBI and SBI instructions will only operate on the specified bit, and can therefore
be used on registers containing such Status Flags. The CBI and SBI instructions work with reg-
isters 0x00 to 0x1F only.
RMW in any system is when you read a value , modify it and then write it back
Using an image that showed this code compiled to an SBI instructionActually this is not an RMW operation
SBI is a Read-Modify-Write instruction
In SBI 0x5,0 read and write operations are missing. Only modify is there
You mean the mega16 datasheet?Please post the link for each document you use as reference. Users don't have to search in the web, you could make it more convenient by posting the web location of those very documents.
I think that this thread has nothing more to offer to members, I am bowing out. OP took a clear picture.
:shock:insulting other members with expressions like “like it or not”,
Sorry, couldn't leave that unanswered. SBI in ATmega16 is an RMW operation. Nothing to do with other stuff I said in the last two posts.all this to cover the fact that in no point in this thread you admit that SBI is a RMW operation
