ATD <phone #> problems
terka
Full Member level 1
atd command
Hi
1.- Ericsson r520
2.- DRS-11 data cable (serial com port) conected on PC
3.- WinXP Hyperterminal software
I make a call using: " ATD <phone number><CR>" ====> its working very well
When call is on, then I try to send DTMF using: " AT+VTS=<DTMF> "
But when a put the "A" character in hyperterminal the call terminates, and i can´t send the tone what i wich.
This is incorrect operations or ist normally?
I hope you cooperations
Thank you
Bye
Added after 1 hours 51 minutes:
Hi
The answers is:
atd<#>;<CR> ======> working with ";"
after;
at+vts="0" =====> working when call is on
WOW
the ";" character was the problem....however, without ";" the call is successful too, but the call drops when press any key in hyperterminal...
Its easy send this command to cell phone from a PIC 16f84, and my project is remote control with SMS and DTMF....some times sms delivery is very slow...In fact, DTMF is faster and reliable......
Bye
at command atd
Hi terka,
If you will read in the AT command set, you will see this:
Dn Dial
This command instructs the modem to begin the dialing sequence. The dial string (n, including modifiers and the telephone number) is entered after the ATD command.
A dial string can be up to 40 characters long. Any digit or symbol (0¾9, *, #, A, B, C, D) may be dialed as touchtone digits. Characters such as spaces, hyphens, and parentheses do not count - they are ignored by the modem and may be included in the dial string to enhance readability.
The following may be used as dial string modifiers:
L Redials last number. Should be the first character following ATD, ignored therwise.
P Pulse dialing.
T Touch-tone dialing (default).
, Pause during dialing. Pause for time specified in Register S8 before processing the next character in the dial string.
W Wait for dial tone. Modem waits for a second dial tone before processing the dial string.
V The modem switches to speakerphone mode and dials the number. An ATH command may be used to disconnect the voice call.
@ Wait for quiet answer. Wait for five seconds of silence after dialing the number. If silence is not detected, the modem sends a NO ANSWER result code back to the user.
! Hook flash. Causes the modem to go on-hook for 0.5 seconds and then return to off-hook.
; Return to command mode. Causes the modem to return to command mode after dialing the number, without disconnecting the call.
^ Disable data calling tone transmission.
S=n Dial a telephone number previously stored using the &Zn=x command (see the &Zn=x command for further information). The range of n is 0—3.
$ Bong tone detection.
So here you can find your asnwer why ; was working.
Good luck.
atd dial
Hi
The asnwer is:
Can you send o tell us where you found that explanation about AT command??
Thank you very much
