AT89C51 based wireless RF Transmitter and Receiver
karangp
Hi
im using AT89C51 microcontroller for transmitter and receiver side.
wireless module is TWS 432A (Tx), RWS 432A(Rx)
I use serial communication to transmitt simple 8-bit data over wirless tranmitter TWS-432A. and the same i receive data to another microcontroller using Receiver RWS - 432 module, i can send more than three or four data to transmitter side. but i cann't receive the same data at receiver side.
in my project is sending 8-bit data from one Mc to another Mc over wirless medium, then received data should be viewed in system hyperterminal via serial port at the receiver side. i can't get exact 8-bit data, some datas are losing:?:.
for your ref : here with i attach my program listing for TX and Rx
Transmitter Program
org 000h
MOV TMOD,#20H ;timer 1, mode 2
MOV TH1,#-6 ;4800 baud
MOV SCON,#50H ;8-bit, 1 stop bit, REN enabled
SETB TR1 ;start timer 1
AGAIN: MOV A,#"A" ;transfer " "serial data transfer subroutine
ACALL SEND
MOV A,#"B"
ACALL SEND
MOV A,#"C"
SJMP AGAIN
SEND: MOV SBUF,A ;load SBUF
HERE: JNB TI,HERE ;wait for last bit to transfer
CLR TI ;get ready for next byte
RET
end
Receiver program
org 00h
MOV TMOD,#20H ;timer1, mode 2 (auto reload)
MOV SCON,#50H ;8-bit, 1 stop, REN enabled
THIS IS USED TO RECEIVE DATA SERIALLY VIA WIRELESS
HERE: JNB RI,HERE ;wait for char to come in
MOV A,SBUF ;save incoming byte in A
MOV P1,A
ACALL TRANS
CLR RI ;get ready to receive next byte
SJMP HERE
THIS ROUTINE IS USED TO SEND, RECEIVED DATAS TO SYSTEM'S HYPERTERMINAL
TRANS: MOV SBUF,A ;load SBUF
HERE1: JNB TI,HERE1 ;wait for last bit to transfer
RET
end
please can u give suitable solution for that project.
my email id: xxxxxxxxxx@gmail.com[/color][/u]
MOD: Please note that we dont entertain private sharing. You need to reda rules/ announcements again.
It looks like you have to "slow down" your transmitting mcu. Look what is happening: transmitter sends byte after byte and you expect the receiver to receive one byte and re-transmit it, while in the same time next byte from the transmitter is on its way ..
After CLR TI insert 1ms time loop in the transmitter's SEND subroutine ..
Regards,
IanP
    karangp
thaks for your suggestion, i will try it now. i will keep in touch with you.
Out of curiosity, what kind of antenna did you use?
Maverick Max
hi
does your transceiver support 4800 bps ?
start from low speeds first ,
and only on one way transmitting first ,
then go to full duplex and 4800 baud .
and set TI at first of the program , means MOV SCON,#52H except MOV SCON,#50H
regards,
