ediamondsrt
Junior Member level 3
I have a Telit GL865 GSM/GPRS module which is connected to a Single Board Computer (running ARCH Linux.) via Serial Port. I have implemented For GPRS connection, PPP connection as indicaten on this page: **broken link removed**
I can read Cell Tower Signal Strength Level by the following AT Command: AT+CSQ?
But i can not use AT commands (AT+CSQ?) if PPP connection is active. First i need to detach/release PPP connection then i can use AT commands.
Reconnection to the GPRS tooks about 2-3 minutes but i do not want to wait for this delay.
IS there any way to check Cell Signal Strengt Level or running this AT command (AT+CSQ?) without closing/disconnecting the PPP Connection?
Regards,
Regards,
