shaiko
Advanced Member level 5
I'm designing an asynchronous FIFO.
While the rightmost bits of the write and read pointer vectors are used for the actual write and read addresses - the MSB is used only to set the control flags (almost full \ full \ almost empty \ empty).
The signals are defined as follows:
Here's the write clock domain process where I set the "almost full" and "full" flags (I use a similar process in the read clock domain to set the "almost empty" and "empty" flags).
Note: you won't see it in my code - but consider the pointers to be gray enconded, synchronized to the other clock domain and decoded back to binary for use. with this in mind, please tell me what you think about the write domain process:
signal wp , rp_from_read_clock_domain : unsigned ( x downto 0 ) ; -- read and write pointers
signal write_address , read_address : unsigned ( x - 1 downto 0 ) ; -- read and write addresses
write_address <= wp ( wp ' high - 1 downto 0 ) ;
process ( write_clock , reset ) is
begin
if reset = '1' then
afull <= '0' ;
full <= '0' ;
wp <= ( others => '0' ) ;
elsif rising_edge ( write_clock ) then
almost_full <= '0' ;
full <= '0' ;
if write_request = '1' then
wp <= wp + 1 ;
end if ;
if
wp ( wp ' high - 1 downto 0 ) = rp_from_read_clock_domain ( rp_from_read_clock_domain ' high - 1 downto 0 ) and
wp ( wp ' high ) /= wp ( wp ' high ) then
full <= '1' ;
else
full <= '0' ;
end if ;
if rp_from_read_clock_domain ( rp_from_read_clock_domain ' high - 1 downto 0 ) - wp ( wp ' high - 1 downto 0 ) <= afull_threshold then
afull <= '1' ;
else
afull <= '0' ;
end if ;
end if ;
end process ;
