asymmetric pulse delay (pulse extender)
aniccame
Newbie level 2
Newbie level 2
I am working on a circuit that uses four phases of a 74HC4017 johnson counter and 2 x 2 74HC32 OR gates to create two square waves phase shifted by 90 degrees.
It is almost perfect, except on the OR gate output, I need to output to stay high as each input goes high. However, due to propogation delay in the Johnson Counter and wiring, there is a very short amount of time when the output of the OR gate goes low. It's so brief it isn't even registered on my 20 MHz scope. However, I need to eliminate it for my application (driving IR2110 mosfet drivers).
The circuit is operating between 10 Hz to 1 MHz.
I need the first pulse that goes into the OR gate to be extended by around 100ns or 200nS. I don't want to delay the rising edge of the pulse, just delay the falling edge.
I think I have a resolution that I stumbled across by using a diode, resistor, and schmitt trigger. I will post it here if it works.
If anyone has any ideas or questions they would be greatly appreciated!
This has been resolved.
I needed to use higher value power supply bypass capacitors in the circuit.
