marsgod
Member level 4
astro lef2a
hi,
I used Astro for linux , and tried a demo IC design .
I have a foudry lib in lef format and the tech file.
For Astro work with it's own lib format, I have to generate a apollo lib
with the provided tool:
lef2A
1. I used Astro create a library with the fondry's tech file, named "A"
2. lef2A -LIB A -LEF io.lef
3. lef2A -LIB A -LEF sc.lef
4. The "A" library created....
5. goto Astro, build my main library ...."B"
6. Verilogin->Add Ref
but when I re-open my main library "B",
Astro said that the ref library "A" has 4 metal layers and the "B" has 5
metal layers .
what's wrong?
The same tech file used to create both libraries.....
Any suggestion?
thanks..
marsgod
hi,
lef2A
metal layers .
what's wrong?
Any suggestion?
thanks..
marsgod
