ElectroNewbie
Newbie level 3
Hi, this is my first post so please let me know if I'm in the wrong place
I'm trying to find the simplest circuit diagram possible and hopefully with no soldering, (I'm very new to this) for what I think is termed an Astable multivibrator
I want to create a seesaw effect with a metal bar on a central swivel point with an electromagnet underneath each arm of the seesaw. The circuit should switch on the current on one of the electromagnets and off on the other and then swap over. This would make the metal bar move like a seesaw.
I would like to be able to adjust the speed that the circuit switches back and forth from about 1 cycle every three seconds to about 5 cycles a second. I think this would be with a variable resister? The circuit for the electromagnets would be separate to this circuit which would only do the switching. Would this be difficult to accomplish?
Thank you
Thank you
