javi
Junior Member level 1
hi ,
i am using assura for DRC check and LVS embdeed in DFII framework (IC5.0). During first run it works properly .
when i run it for the second time after first run on the same design (it may be schmatic, layout..etc) it diaplays the messgae " current job is still active . do you want to close the view and run " .
when i click yes the system hangs for a while.
so every time i come out of ic5.0 then reopen the design and doing it.
Sometimes i give kill coommand to ic exe and assura exe's . how to rectify this problem.
assura and ic5 are installed in differnt directories. The assura path is specfied in ic.cshrc file.
javi
javi
