Assura RCX / QRC Questions
pokemonstation
Junior Member level 1
assura qrc
Hello, I am having trouble running Assura RCX. I am currently using Cadence Virtuoso 6.1.3 with IBM PDK cmos10lpe (65nm). I ran Assura LVS on a simple inverter cell and it has no probem passing LVS check (I ran DRC on the same inverter with Synopsys Hercules because the IBM PDK that I am using does not provide a rule set for Assura DRC).
Then I tried to run Assura RCX by selecting "Assura -> Run RCX" from the Virtuoso Layout Editor menu. For some unknown reason, it causes Cadence to crash. Here is a part of the log file
\o Assura RCX Run: Loading Technology Data. Standby...
\a leSetLSWBBox(list(9:171 159:871))
\r t
\r t
\r t
\r t
\r t
\w *WARNING* No tech dir found for tech name NONE
\w *WARNING* Current technology is "NONE", but .tpl file was not loaded for some reasons.
\o Template file "/n/homeserver2/user2a/mcwang/cadence/IBM_PDK/cmos10lpe/relRF/cdslib/cmos10lpe/.rcx_setup.tpl" was successfully loaded.Warning: SNA Tech Dir is not a directory, trying the default SNA Tech Dir
\o (dbPanic) dumping stack
\o dbPanic+304()
I am especially puzzled by the warning "*WARNING* No tech dir found for tech name NONE" because I did specify the technology in Assura -> Setup -> RCX Setup or something like that. I definitely had specified the technology when I ran LVS earlier.
I have another question regarding Cadence QRC. Is this part of Assura instalation? I couldn't find anything that resembles QRC in the Software Download page. The IBM PDK that I am using supports QRC, but I couldn't find it in the Assura menu from the Virtuoso Layout Editor menu.
Thanks in advance
*warning* no tech dir found for tech name none
"No technology directory found" is a known problem with IBM kits using QRC/RCX extraction. DRC and LVS will run smoothly, but QRC/RCX don't find the tech data.
First of all, your PDK should be loading QRC, not RCX. To do this, do the following:
1. in your startup script, set QRC_ENABLE_EXTRACTION="t"
2. in your path, make sure EXT comes before ASSURA.
Then launch QRC by Assura->Run RCX... and you will get the following:
\o QRC Run: Loading Technology Data. Standby...
\w *WARNING* Current technology is "8RF_DM_32", but .tpl file was not loaded for some reasons.
\o *Info* Default Substrate Tech Dir is not defined, replaced with the empty nameWarning: Substrate Tech Dir is not a directory, trying the default Substrate
Tech Dir
... (some warnings)
\o Load complete.
\w *WARNING* No technology directory found.
To setup QRC you need to set the Technology Directory to /<path_to_pdk>/Assura/QRC/<metallization_stack>, and in the Extraction tab set Reference node to /gnd!. I'm not sure but you can try setting RSF File to /QRC/<stack>/LVSinclude.rsf. For extracting L and K you need to specifiy the User Region field and whichever metals you want to extract L and K for.
If you're a mosis customer, try support@mosis.com or join **broken link removed**
Hope this helps.
assura rcx no technology directory found
Yes I second oermens comments as I also had the same problem and the setup suggested by oermens is the only way.
run cadence qrc
Hi Michael,
Can you please provide IBM PDK, I can install at my site and help you to resolve this problem.
Please mail it to hoizal@yahoo.com
Thanks,
hoizal
cadence qrc
This IBM PDK problem also bothers me from time to time. Thanks for providing such a solution....
