Hello,
I got another question which I want to ask. I hope you can help me. The situation in short notes:
* Chip (with IO cells) finished and Streamout as GDSII and Verilog
* GDSII Xstream In to Virtuoso
* Assura streamed in Layout vs. Verilog Netlist (+ the Spice Netlists of the std. cells)
Everthing is working fine, but I get lots of Missmatches. Most of them are VSS and VDDD Ports of all std cells in the Layout. I read some in www/forums and got the Information to manual create global nets in the Layout. I tried this with "create pin" and "create label". But the results are the same. So my question is, how to solve these errors? I don't think that they are real or in more detail:
* Have I to create such global nets in virtuoso? Why? Because the Verilog does not have such definitions for VDD, VSS.
* Where I have to create them? On the internel power rings or at the pads of the IO power cells at the chip boundary.
* How I have to create them?
* Are other solutions possible?
Because I'm a digital designer guy, I have not much experience with virtuoso. Therefore, it would be create if you can explain me in detail what to do. Thank you so much.
Greetings from Germany,
Marc
PS: Import of the Verilog to a a Virtuoso Schematic does not work due cadence internal memory violation. Therefore the only way is to do this directly in LVS with verilog and spice netlists.
