Assura Istallation Problem ? Need advice !!!
wls
Member level 4
Member level 4
Singapore
Hello . I installed RH7.2 then upgrade it to RH9.0. Then i downloaded Assura 3.0 linux to my hardisk and installed from there. I installed from user account and not from root as it is not advisable . But when I installed there are error. Please look at the text problem and give some comment ???
Located CDROM at /home/wls/Assura/ASSURA30-50_lnx86.Base/CDROM1
\c
Specify path of install directory \c
[OR type [RETURN] to exit]: \c
/tools
Directory /tools does not exist. Create? [y/n]: \c
n
tools
Setting up softload for lnx86 in /home/wls/Assura/ASSURA30-50_lnx86.Base/CDROM1/tools
\c
SoftLoad has been successfully setup in the directory:\c
/home/wls/Assura/ASSURA30-50_lnx86.Base/CDROM1/tools\c
\c
You can install or update products by running:\c
/home/wls/Assura/ASSURA30-50_lnx86.Base/CDROM1/tools/install/bin.lnx86/softload\c
Do you want to start softload? [y/n]: \c
y
Starting up SoftLoad in GUI mode \c
DISPLAY environment variable is set to :0.0\c
If you do not see the SoftLoad console \c
window or the SoftLoad ASCII menu and\c
SETUP.SH seems to be hanging then kill this \c
process.\c
Set your DISPLAY environment variable to a proper\c
value and manually start SoftLoad by typing: \c
\c
WELCOME TO THE
CADENCE INSTALLATION UTILITY,
SOFTLOAD 6.0
Copyright (c) 1996-1998 Cadence Design Systems, Inc. All Rights
Reserved. Unpublished -- rights reserved under the copyright laws
of the United States.
Copyright (c) 1996-1998 UNIX Systems Laboratories, Inc. Reproduced
with Permission.
THIS SOFTWARE AND ON-LINE DOCUMENTATION CONTAIN CONFIDENTIAL INFORMATION
AND TRADE SECRETS OF CADENCE DESIGN SYSTEMS, INC. USE, DISCLOSURE, OR
REPRODUCTION IS PROHIBITED WITHOUT THE PRIOR EXPRESS WRITTEN PERMISSION OF
RESTRICTED RIGHTS LEGEND
Use, duplication, or disclosure by the Government is subject to
restrictions as set forth in subparagraph (c)(1)(ii) of the Rights in
Technical Data and Computer Software clause at DFARS 252.227-7013 or
subparagraphs (c)(1) and (2) of Commercial Computer Software -- Restricted
Rights at 48 CFR 52.227-19, as applicable.
-------------------MAIN MENU----------------------
The available options are:
1) Load Available Products
2) List Installed Products
3) Remove Installed Products
4) (unavailable option) Configure Installed Products
5) (unavailable option) Test Installed Products
6) Update Installed Products
h) Help
q) Quit
Type your choice: [ 1 ] 1
CD#1 of the media set being used is required.
You must now identify where the CD-ROM is mounted.
1) Local (mounted to this machine)
2) Remote (mounted to another machine)
m) Main Menu
h) Help
Specify the CD-ROM mount point
1) /cdrom
2) Other
m) Main Menu
p) Previous Menu
h) Help
Type your choice: [ 2 ] 2
Type the CD-ROM mount point: [ /home/wls/Assura/ASSURA30-50_lnx86.Base/CDROM1 ] /home/wls/Assura/ASSURA30-50_lnx86.Base/CDROM1
tar: This does not look like a tar archive
tar: Skipping to next header
tar: Archive contains obsolescent base-64 headers
tar: Error exit delayed from previous errors
/home/wls/Assura/ASSURA30-50_lnx86.Base/CDROM1/tools/install/bin.lnx86/softload: line 1412:
Could not extract information from FS.0 of CD#1.
Could not get platform or release information: command not found
h) Help
q) Quit
Thx and regards.
There may be installation error when u upgrade to rh9.
Search the place, i think someone post a 'cure' for that.
fyi, i have no problem installing Assura in rh7.3
that is true for 7.3 not problem.
still it does not work so well, as I had trouble while integrating @ssura into ic5o, :lol:
I heard about installation tar problems on linux many times.
I think you are using first Assura release for linux.
Simple solution:
1. Install this package on solaris.
2. Move your installation folder to linux.
Good luck.
to :lctlcm
I have install assura in redhat7.3,and set ASSURAHOME="assurahome" in bashrc,assurahome is what i have install the assura,but assura doesnt appear in virtuoso as calibre does,why?
does assura use the same license as ic5033?
I suppose that assura has its own features' license. Of course, you can include them into ic5033's, if they are licensed by the same server, or even better if they are all node-locked type only.
why not try to install on RHEL 3.0 ?
