Assura installation procedure
Kicchan
Member level 3
Member level 3
I am using IC5141 and I have neither Assura nor Calibre installed. I am going to download one of these tools. Given a Cadence version, is there any rule in order to choose Assura or Calibre?
If I choose Assura, which are the steps to follow after installation? I know I should add some settings in my .tcshrc but I don't think that's all.
I have found other similar topics around the forum but none of them explains the complete procedure because the one who posted the topics had already experience.
Please, help! :cry:
HI Kicchan,
There is no difference. You can install any tool first.
(a) After installing ASSURA and QRC packages, you need to set you script to:
export QRC_HOME=/installation_path/EXT/
export ASSURAHOME=/installation_path/ASSURA
export PATH=$ASSURAHOME/bin:$ASSURAHOME/tools/bin:$PATH
export QRC_ENABLE_EXTRACTION=t
(b) After installing Calibre package, you need to add the following lines in your script:
export MGC_HOME=/installation_path/ixl_cal_xxxx/
export PATH=$MGC_HOME/bin:$PATH
export TECHDIR=/installation_path/design_kit/last_version/
Regards,
Thanks a lot for your help, palmeiras!! :smile:
