ASSURA 41 LVS Problem
Dioni
Newbie level 3
Newbie level 3
Hi all,
I'm using IC615 with ASSURA41 and i having a problem with the LVS. When i run it it has the following error:
Starting dfIIToVdb...
/root/cadence/installs/ASSURA41/tools/assura/bin/32bit/dfIIToVdb: /root/cadence/installs/ASSURA41/tools/lib/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /root/cadence/installs/IC615/oa_v22.41.027/lib/linux_rhel40_gcc44x_32/opt/liboaPlugIn.so)
/root/cadence/installs/ASSURA41/tools/assura/bin/32bit/dfIIToVdb: /root/cadence/installs/ASSURA41/tools/lib/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /root/cadence/installs/IC615/oa_v22.41.027/lib/linux_rhel40_gcc44x_32/opt/liboaCommon.so)
*WARNING* Translation abnormally terminated!
***** aveng fork terminated abnormally *****
*WARNING* aveng exit with bad status
*WARNING* Status 256
*WARNING* Assura execution terminated
Could you help me?
Thanks
Dioni
Hi Dioni ,
I have the same problem ,did you get it?
Maybe ,you could help me!
Thanks
lccchc
