rezaf
Hi, I have many boards that use ASSR1510 in outout of microcontroller for switching battery voltage on and off.
But the behavior of this component is strange. When the MCU drive led of ASSR through bias resistor (560 ohm), the ASSR works Ok but after a short time, the output voltage of MCU start to drop from 4.9v to about 1v and the ASSR go off also the output of ASSR start to drop the voltage.
