Assign fix values in vhdl
sheikh
Hello Dears
How can I use fix values and coefficients in vhdl? Does these fix values synthesisable? For instance in equation "Y= 23X" , Is it enough to write :
Signal a :STD_LOGIC_VECTOR :=  (0=>'1', 1=>'1', 2=>'1', 4=>'1', others=>'0');
y<= a*X;
I did it in my code and the simulation result was ok, But in RTL schematic the port that related to this value eliminated from multiplier and Ise shows this warning:
"Signal <a> is used but never assigned. This sourceless signal will be automatically connected to value 00000000000000000000000000010111.
Is it a problem for real implementation? ( I mean on FPGA)
Also, it happen when I put some fix values at the input of MUXes.
Regards
mostafa
If fixed value is provided on S input of MUX then MUX will get optimized. It is not a problem for real implementation.
Reactions: sheikh
    sheikh
Thanks Dear dftrtl
So I can consider " signal" for this kind of values ( I mean, fix values ) and use them in my code without any worry for hardware implementation. true!
If these values are constant, why not use a constant instead of a signal?
constant a : integer := 10;
Reactions: sheikh
    sheikh
Thanks TrickyDicky, Yes they are constant, Does constant synthesis able? Also, Could you please tell me, what is the differences between assign fix values by "signal" or by "constant" in a real implementation? (I mean From hardware view).
Thanks in advance
Mostafa
There is no change by having a constant signal or constant itself.
Reactions: sheikh
    sheikh
