Assembly Programming for tx(TLP434A) & rx(RLP434)!!!! UR
tschen
Junior Member level 3
tlp434a
How can i program to generate the signal pulses for the tx/rx module using a 4Mhz clock? I'm using assembly programming.
rlp 434
First, chose a encode / decode system.... once you do that, is only matter of making the pulses out throut the data pin of TLP434, then the RLP434 must be able to read it from its data pin and decode the data based on the coding you selected to use in your project.
good luck
