assembly language ( intel 8088/8086)
goodtime
Member level 2
Member level 2
intel 8088 assembly language
write assembly program that will add two values each 32 bits??
any one can help me
If I remember correctly, it is:
<pre>
MOV CX,SIZE/2 // Number of words
MOV BX,0 // Offset into Array
CLC // Clear Carry
TOP MOV AX,[BX+A] // Load 16 bits of A
ADC AX,[BX+B] // Add 16 bits of B
MOV [BX+C],AX // Store 16 bits of C
INC BX // Increase BX to
INC BX // next word index
LOOP Top // Repeat until CX=0
</pre>
Added after 3 minutes:
Sorry for the crappy formatting. Hope it helps!
Added after 2 minutes:
This pdf file might be helpful:
https://www.cs.umass.edu/~verts/cmpsci201/spr_2004/Lecture_03_2004-02-02_The_8088_processor.pdf
    goodtime
