Assembly code for counting pulses during 10 seconds
djalli
Advanced Member level 3
1600 Pennsylvania Avenue, Washington DC 20500
count for 10 seconds
I am begginer in PIC. I am doing it wrong. I know.
I am inputing this pulse train in figure in 16F... uC microcontroller.
Can you post exact code for a variable in assembly which holds the counts of how many pulses where detected within 10seconds.
Pass it then to another variable by overwriting it.
Afterwards to reset itself and count again for 10 seconds more. Loop.
I am very sorry :oops: to ask this simple question but thank you a lot. :)
Re: count for 10 seconds
1)Please tell me the speed your pic is running at.
2)Are you using tmr0 for anything in your prog.
3)Which port-pin is reading the pulse-train.
Cheers
Raticus
HI,
What is the max. no. of pulses you want to measure during this period (10s) ?
SphinX
SphinX said:
HI,
SphinX
hello Phinx. I dont know nr. of max pulses. A ballpark figure could be 2000.
Thank you.
Hello Raticus
3MHz
Not now.
Right now I have all pins available
Thank you. Thanks a lot
Hi Djali
When you say 3Mhz is that your xtal freq. or is it 12Mhz xtal/4?
I will do the code for you.
HI,
look at
Bye
