jcwc84
Newbie level 2
Since it's my first post, I'm not sure whether i post in correct section or not.
If it isn't correct, then help me move to correct section.
I also need to clarify that my English very poor. Very Happy
K, i will brieftly explain my project description.
I want to modify Morse code transmitting system by replace the electric telegraph with CPU. So there's two CPU, one at transmitting and another at receiver side.
So i need to write a Morse code encoder programming on the transmit side, and another Morse code decoder programming on the receiver side.
About the program, i plan to use visual basic to write it out, with we can type what we want in a box, then press PLAY and it will find sound clip for every word, and when i press SEND, it will send the data to transmitter circuit. Next to receiver circuit and go in CPU again for decoding program.
The problem is i had no idea to integrate the circuit and the programming software. I have no idea how it works.
For the transmitter circuit, it need to have SERIAL PORT use to connect to CPU. But i'm not sure how's the circuit's design. I only search for circuit which used infrared but it only limited for short distance. I need a transmitter and receiver which can transmit and receive within 2 to 10 meter. Anyone of u know any circuit like? I need to know what components i need.
If there's any words which confuse you/doesn't clear for u, u may ask and i will answer after check this post often as i could.
I really need ur comments, suggestion and help Smile
