What is the input voltage range?
So the input current is >220 amps DC? do you realise this?
i mean 220dc 10A
I think you still missed the point, remember Watts = voltage * current.
Output power = 220V * 10A = 2200 watts
Input power ~= output power = 2200 watts
Input current = 2200W / 10V(min) = 220 AMPS at the input.
Is this really what you want to do? You'll need one HUGE DC source, and a pretty big transfomer to handle the boost conversion for that much power.
hi
use LM324 IC and make a switch mode power suplly
could you share the circuit?
If you're going to go the route of a SMPS, I'd recommend using a chip designed for SMPS control. National (national.com) has a number of these ICs. For the voltage range you are talking about, I'd go with a flyback topology. They are relatively straightforward, but do require some familiarity with electronics and the design equations. If you aren't familiar with them, I'd go hunt around on the web for flyback power supply designs, and start understanding how they work (lots of website out there they talk about the threory of operation). I'd also search on here for other threads about flyback converters. Also, a book on SMPS design could be very useful, if you are trying to build something from scratch.
I found this article in a quick search. It would be worth a look.
It's meant to run from a 12V battery, so you'll have to verify that the design can operate from 10-20V at the input without burning up any of the devices.
