ASITIC to Cadence Import problem
lavitaebelle
Member level 4
Member level 4
asitic to cadence
I am trying to import a spiral inductor designed in ASITIC to cadence. So I create a CIF file in ASITIC and try to import it into cadence. When I try to do that I see the following errors:
* Fatal * No layer defined in cell before data read. Layer Table may be required in templete file.
* Fatal * (piReadCif) - cifFile (5-line 65-char = ;) syntax error.
Can anyone provide me with leads on this?
Thanks in advance.
Had figured out the method to import.Thx for the file anyways.
hey lavitaebelle, did you ever figure out what the problem was? I am having hte same problem now and im not sure why.
Me too, i have the same problem.
Hope we find the adequate answer :D
