carporsche
Junior Member level 2
ASIC CMOS opamp
Hi guyz,
The following is my design problem.
Need to design a CMOS opamp in the TSMC 0.35um process. Supply voltage is 3.3V
Some of the design considerations are as follows:
1. The opamp will be set-up in the non-inverting configuration.
2. high open loop gain >80dB
3. high unity gain bandwidth requirement > 300MHz
4. needs to have a sufficient closed loop gain
5. output voltage level needs to be at 0V.
Have started the design assuming a 2-pole amplifier. Thinking of a design with 2 stage with miller cap and nulling resistor. This provides high gain but not sufficient bandwidth. What techniques can be used in this config?
Any inputs is greatly appreciated!
thanks!
Hi guyz,
thanks!
