Ascii to BCD Conversion
gauravkothari23
Advanced Member level 2
Hi all.
I am making a simple project where i need to display the contains of Array to seven segment display.
for ex.
unsigned char array[4]={"1234"};
also i have four seven segment displays where i need to display 1 to segment 1, 2 to segment 2, 3 to segment 3, 4 to segment 4.
common anode segments are connected to PORT 1 of 89S52 Microcontroller.
how can i do it. can anybody provide me some logics to do it.
No need to convert to BCD, just create a second array containing the bit pattern of segments and drive the port with it directly.
hint: think of the segments as bits in the port, for example segment A = bit 0, segment B = bit 1 and so on. Then work out the bit pattern and hence numeric value for the segments you want lit for each digit.
Be careful not to confuse segments and digits. A digit is the whole display module consisting of seven segments and maybe a decimal dot, a segment is the individual bar that makes up the shape of the digit.
Brian.
Also be aware that strings in most compilers are null terminated which mean that "1234" is actually 5 characters long.
Susan
