ARM7 lpc214 help about VIC_Vector_IRQ
hbaocr
Full Member level 4
Full Member level 4
Hochiminh City university of technology (VietNam)
www.deeforum.net
lpc214
helllo , all friend
I have just learn ARM7 LPC2148 and I have some problem about VIC when it assigned to IRQ_vector.My problem means, how can I use more than one IRQ interrupt (IRQ vector) at the same time . and the code for it. Some friend tell me After I allow Interrupt sources which I want ,I can assign each ISR_routine functions to VICvectorAddr0,VICvectorAddr1,...etc(example VICvectorAddr0=unsigned(ISR_routine function1)
VICvectorAddr1=unsigned(ISR_routine function2)
) but I don't know how Arm can recognise which ISR_routine function service for which Vector IRQ interrupt-sources.
lpc214 programming
You need to read about the Vector Control Register (VICVectCntl).
The Vector Control Register contains two fields: a channel field and an enable bit. By programming the channel
field, any interrupt channel may be connected to any given slot and then activated using the enable bit. The
priority of a vectored interrupt is given by its slot number, the lower the slot number, the more important the
interrupt.
