[ARM] IAR Embedded workbench error!
mucko
Member level 1
Member level 1
iar warning
Hi everbody!
I am new to ARM.I have made a wiggler jtag then i try
to debug/download my program to OKI's ML674061 demo
board.Then i came across the following errors from IAR
embedded workbench:
Mon Sep 05 10:40:53 2005: JTAG API v32.7, Wiggler
v1.39, ARM ID: 3F0F0F0F
Mon Sep 05 10:41:36 2005: 65536 bytes downloaded and
verified (1.52 Kbytes/sec)
Mon Sep 05 10:41:36 2005: Warning: Target
inconsistency detected at Memory address 0x000001C0
inconsistency detected in Memory range
0x00000AC8-0x00000AD3
0x000003B0-0x0000047B
0x00000AE0-0x00000AE3
0x00000AD4-0x00000ADF
0x0000047C-0x000009DF
0x00000AE4-0x00000B07
0x000009E0-0x00000A8B
0x0000033C-0x00000341
0x00000A8C-0x00000AA7
0x000003A0-0x000003AD
0x00000AA8-0x00000AC7
0x00000B08-0x00008B05
0x00008B06-0x0000FFFF
Mon Sep 05 10:41:36 2005: There were warnings during
download, see Log Window
Mon Sep 05 10:41:40 2005: Loaded module
Mon Sep 05 10:41:40 2005: Target reset
So everthing seems to work fine and i see no error
message but the program that i compiled doesnot work
anymore.I think the problem is due to the Target
inconsistency in various memory ranges?
If any idea for this,
please help?
best regards...
warning: target inconsistency detected at memory
Check is there any specific initialization need to be done for your target. If it is required you need to write some start up script to make the board working. the script will be automatically executed before the program download.
This types of problems will happen mostly when you are using SDRAM in the target. I do not have hands on working exp with ARM.
Cheers
iar workbench warnings
Hi
Don't use IAR embedded workbanch for ARM with DIY wiggler the support is not working well
This kind of wigglers work good only with crossworks from ARM IDE & GNU ARM +GDB
If you wish to work with IAR EWB buy there J-LINK JTAG adaptor
All the best
Bobi
