// Cortex-M0 DesignStart C program example
// Include standard C library and RealView Compiler header.
#include <stdio.h>
#include <time.h>
#include <rt_misc.h>
// The following code implements all the functions required for semihosting
// using the Cortex-M0 DesignStart testbench, mapping output from C to the
// console output of the testbench.
// Disable the inclusion of semihosting support; see the "ARM Compiler
// toolchain Using ARM C and C++ Libraries and Floating-Point Support"
// (ARM DUI 0475) for further details.
#pragma import(__use_no_semihosting)
// Define where the top of memory is.
#define TOP_OF_RAM 0x20000U
// Define location of C stack and heap
// Initialize stack and heap to span from the end of the zero-initialized
// region to the value defined by TOP_OF_RAM; see the "ARM Compiler toolchain
// Linker Reference" (ARM DUI 0493) and the "ARM Compiler toolchain Using ARM
// C and C++ Libraries and Floating-Point Support" (ARM DUI 0475) for further
// details.
extern unsigned int Image$$ZI$$Limit;
struct __initial_stackheap
__user_initial_stackheap
(unsigned int r0,
unsigned int r1,
unsigned int r2,
unsigned int r3)__value_in_regs
struct __initial_stackheap sh;
sh.heap_base = Image$$ZI$$Limit;
sh.stack_base = TOP_OF_RAM;
sh.heap_limit = sh.stack_base;
sh.stack_limit = sh.heap_base;
return sh;
// Implement the minimum number of functions required to support
// standard C input/output operations without a debugger attached.
// Define the location of the output console in the DesignStart testbench.
volatile unsigned char *console = (volatile unsigned char *) 0x40000000U;
// Implement a simple structure for C's FILE handle.
struct __FILE { int handle; };
FILE __stdout;
FILE __stdin;
// Implement file IO handling, only console output is supported.
time_t time(time_t* t) { static time_t clock = 0; return clock++; }
int fputc(int ch, FILE *f) { *console = ch; return ch; }
int ferror(FILE *f) { return 0; }
int fgetc(FILE *f) { return -1; }
int __backspace(FILE *stream) { return 0; }
void _ttywrch(int ch) { fputc(ch,&__stdout); }
// Writing 0x4 to the console causes the DesignStart testbench to finish.
void _sys_exit(void) { fputc(0x04,&__stdout); while(1); }
// Implement the vector table in its own area to facilitate linking first
extern void __main(void); // Use C-library initialization function.
__attribute__ ((section("vectors")))
static void (* const vector_table[])(void) =
(void (*)(void)) TOP_OF_RAM, // Initial value for stack pointer.
__main, // Reset handler is C initialization.
0, // No HardFault handler, just cause lockup.
0, // No NMI handler, just cause lockup.
0//... // Additional handlers would be listed here.
// Simple "Hello World" program.
int main(void) {
printf("Hello World!\n");
printf("This message was printed from helloworld.c provided\n");
printf("with the ARM Cortex-M0 DesignStart processor\n");
return 0;
