Argon implantation using Silvaco
edu11
Hello,
can somebody please tell me how to implant argon using silvaco?
The classic line "implant argon dose=1e16 energy=1 tilt=7 bca fullrot amorph" doesn't seem to work.
Argon is not simulated as it does not contribute electrically. You would typically use argon the pre-amorphise the surface being implanted.
So for simulation, skip the argon implant then use the "amorph" statement to tell the simulator the surface being implanted is amorphised and to ignore channeling effects.
Reactions: edu11
    edu11
Thank you for replying. Unfortunately, argon is not used here to reduce channeling. Argon is implanted using low energy to create traps for charge storage.
Then you would need to try match the trapping parameters to actual experiments. Silvaco (at least the versions I am aware of) cannot do this in the process models (Athena).
