ARES IC Package Problem :(
areebahmed08
Karachi, Pakistan
HI
Im From Pakistan . Im an student of B.E Electronics from NED University .
My teacher gave me the task of making Circuit. Most of the student doing in bread board or vero board but i want to make PCB USING ARES 7
. Im suffering from just one problme i.e. Package of IC
I have to use Intel 8085A Microprocessor but in ARES there is no such package , so now took alternate other 40Pins IC. But im worried about size of the IC :((( Similarly same tension for rest of the 3 IC :((((
If it wont match the size of the actual IC than how can i sold pcb using my IC :((( Plz help me
My Teacher didnt tell me about that , Im a student of 3rd year(5th semister) dont knw much about Microprocessor, but i can tell you all the details mention in my IC which shop keeper gave me :
P8085 AH
L6120078
i '76 '80
Thank you so much for quick response sir :)
Sir How can identify which package m i using ????
Is there any way to find it ??
Sir its 8-Bit HMOS Microprocessor
Usually there is a guide in the datsheet that describes how to read the letters on the chip but I can hardly find a datasheet for it and the one I found has only the footprint of military versions so I have no idea which case you have.
Do you have it in your hands, can you measure the width and length of the chip?
Yes it is in my hand .... Im looking to it in a strange manner :p
by the way in mm ??
Sir
This one i have Kindly Check it
http://xhoba.x86-guide.com/en/collection/Intel-8085AH-2-PDIP-cpu-no9848.html
Sir
Whatever you prefer, I can convert it later
Does it match ?
If it does the DIL40 foorprint of ARES matches it
Yessss Exactly this one i have :))))))
I measured it by ruler just now. Exactly the same package :)
Use DIL40 and enjoy :)
If you want print the board on a paper using the printer when you finish the board and place the chips you have on the paper where they are supposed to be place to check if the footprints are match, if they do then proceed with the PCB development
Thank you so much Sir :))))))
I have taken printout and it fits well i.e. the footprints.. Thank you soo soo much Sir :)
Seems a nice board, just watch the track I show below that has a very thin width.
You can move the track it a little to the right and then increase the width, if you leave it thin like this it can cause problems
and here
Also make sure you have decoupling capacitors (100nF) close to IC supplies
