the clamp is a very important part of converters because it is the one which limits the voltage to the desired value.... snubber is generally used to remove transients in the output.....
actually removing a snubber typically improves performance, or at least efficiency as its no longer consuming any power, though you basically are asking murphy to cook your ic's and transistors
